Subject: DotNetNuke 4.8.4 Released
20 Jun 2008 3:41 AM
DotNetNuke has released version 4.8.4 this month. This has been released due to a few security issues that were found in the 4.8.3 version.
You can download the latest version from the downloads page on www.dotnetnuke.com
jesp17
30 Oct 2008 6:20 AM
Hi Lee,
Is it possible to get a fresh download of DotNetNuke 4.8.4? I can't find it anymore on the site www.dotnetnuke.com. I know there is a newer version 4.9.0 but it's to hard for me to work with it right now. Problem is that I can't follow your skinning tutorials anymore with this newer version.
Kind regards, Jeannine
30 Oct 2008 7:56 AM
Look for the Legacy Downloads link at the bottom of the Downloads page on DotNetNuke.com.
31 Oct 2008 12:15 PM
I have put in a request to the core team to include the DNN-Blue skin with the video tutorials but I am still waiting for a reply.
Forums > Users Lounge > Announcements > DotNetNuke 4.8.4 Released
