| RE: Refreshing Bl... IE by ollep |
| Thanks Guys!! Excelent support. I will - beleive it or not - be away from the computer for three... |
| Parent Portals and SSL by LucianV |
| Hi,I need to install and configure on our server several DNN parent portals (different domain names)... |
| RE: File Manager Upload (intermittent error) by dnnmq |
| Lee, your attention to this issue is truly appreciated because it's driving me nuts.js is included i... |
| RE: Regular restores to local machine by joannew |
| I've opened the tables and there is lots of data in there but nothing when i navigate to user accoun... |
| Duplicate Meta Description and Tag by vdelisi |
| Hi,analyzing my site with google webmaster tool , I've noticed that I have Duplicate Meta Descriptio... |
| RE: Regular restores to local machine by jncraig |
| You can use SQL Server Management Studio to look into your database to see what is there. Your user... |
| RE: How to speed DNN by vdelisi |
| Thansk for your suggestion |
| RE: templates and modules by jncraig |
| Rather than not showing a container, I've taken to using one of Lee's "transparent container with no... |
| RE: My Server's Event Viewer by mgordon |
| Thanks Joe,I'm using SQL Server 2005 (Not Express, but the full version)Mark |
| RE: My Server's Event Viewer by jncraig |
| Mark, This is a new one one me ... so I'll have to ask another stock question. Which version... |
| RE: Issue 22 - Login failed for user xxxx by jncraig |
| Use SQL Server Management Studio or the express version to see which username and password will conn... |
| Issue 22 - Login failed for user xxxx by picoallen |
| Hello,I'm following the 'How to transfer a localhost DNN installation to a live website' tutirial in... |
| Just to let you know, restoring the .bak file now works, by changing the default database for the lo... |
| RE: Epicor by bryan_homey |
| Little background, I am a DNN newbie. I have worked with Epicor for 10+ years. Including populatin... |
| Help! Not sure what's going on. Every ten minutes, on the dot, I am getting an Information log in ... |
| RE: style search CSS or XML by mmcinulty |
| Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha... |
| RE: News Feed from DNN Blog by aggiedan97 |
| Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore... |
| Hello Lee, Thanks for the info, I tried restarting the application but it had no effect. Is there... |
| RE: menu in dotnetnuke by leesykes |
| The page URL option does not have the option to open links in a new window, they will always open in... |
| RE: Only registered users can access some parts of the module by leesykes |
| thanks for posting info, |
