Subject: Type size issues IE6 vs IE7 vs Firefox
DavidWSnow
26 Nov 2007 5:53 PM
In Lee's skin.css for Issue 25 he had some methodology to adjust for the different  default type sizes used by different browsers, not use pixels, and still allow users to personally adjust the type size.
http://www.alistapart.com/articles/howtosizetextincss
is an article on a different way. I haven't tried it yet but it looks interesting.  However, I think it assumes that your text is inside of paragraph tags, so for DNN it may depend on how you have set up the default for the FCK editor.
/DaveS
28 Nov 2007 5:20 AM
Thanks, interesting, both techniques work in a similar way, so it's just a case of which method you find easiest to implement for consistent display of font sizes across the various browsers.
For anyone else reading, the tutorial which demonstrates text resizing in detail is here:
How to create resizable text
Forums > Users Lounge > DNN Creative Articles > Type size issues IE6 vs IE7 vs Firefox
