Subject: upgrade from DNN 3.2.2 to 3.3
eureka
03 May 2006 7:41 AM
Hi Lee
Can I presume to upgrade DNN 3.2.2 to the new release of  DNN 3.3 is as per your video. Also that I can use the same xhtml version of default.aspx.
Regards
Lynn
03 May 2006 8:58 AM
Hi Lynn,
Yes it should be, from Shaun Walkers blog there was no mention of changing the upgrade process, so it should be identical.
Regarding the default.aspx file - it should be ok, but before installing, check the 3.3 version against the 3.2 version and see if there are any differences.
I will let you know if I come across any problems once 3.3 is officially released, thanks,
Forums > Users Lounge > DNN Creative Articles > upgrade from DNN 3.2.2 to 3.3
