Subject: how to add classes in the skin.css to the styles in the fckeditor?
pvratheesh
14 Aug 2007 11:32 AM
how to add classes in the skin.css to the styles in the fckeditor? in the ftbeditor, we can see the default classes in the styles dropdown. but the new classes i created in the skin.css is not coming there. so i used fckeditor. can u plz tel me how to appear those classes? is it possible??
21 Aug 2007 8:42 AM
Take a look at:
Forums > Users Lounge > DNN Creative Articles > how to add classes in the skin.css to the styles in the fckeditor?
