Subject: curiously_green.template is not a valid Portal Template File
tgroman
13 Aug 2007 1:25 PM
Reposting this question to its own thread...
curiously_green.template is not a valid Portal Template File.
Any idea why I may be getting this error when using the Site Wizard to build the curiously_green template?
I've extracted: curiously_green.template and curiously_green.template.resources to \Portals\_default.
Any help would be appreciated...
13 Aug 2007 8:05 PM
I believe that this could be due to an error in DotNetNuke. If you visit snapsis.com, John Mitchell has a solution for you. Look in the DotNetNuke Support forums.
http://www.snapsis.com/DotNetNuke/Support/tabid/560/forumid/15/postid/5716/view/topic/DNN-Release-Information-Bugs-Patches-5716.aspx
tgroman
13 Aug 2007 8:57 PM
Thank you, Joe.
I'd gotten my hands on an older version of John Mitchell's replacement portal.template.xsd.  The link you gave led to a newer version he produced.  It worked like a charm.
Forums > Users Lounge > DNN Creative Articles > curiously_green.template is not a valid Portal Template File
