Subject: AdSense
jackmartin
10 Jul 2007 6:30 AM
Greetings - great site - question...
I am building an AdSense site and I have quickly realized that the "DNN guys" programed the meta keywords tag to include "DotNetNuke" & "DNN" - as a result much of the time Google is serving my site with DNN Advertising - which I do not want - the rest of the time Google is serving the very relevant ads to my site which I do want - can you tell me (us) how to remove the pre-loaded DNN meta tags from my DNN site?
Jack,
Miami, FL
10 Jul 2007 9:59 AM
If you go the admin menu / site settings - here you will see the title, description and keywords metatags.
I would recommend you also create these for each individual page to give you better search engine rankings and closer targetted ads.
Go to the page settings for each page and at the top you will also see a section for the title, description and keywords.
Hope this helps,
03 Aug 2007 9:33 AM
Also, go to:
Host menu / site settings /Appearance
untick - Show Copyright Credits
