Subject: Red Leaf CSS Skin
KMOwen
04 May 2007 2:18 AM
Hi Lee
I have just installed the 3 Pane Red Leaf CSS Skin with the Horizontal Menu in DNN 4.5.1. Everything works great apart for one small inconvenience.....
When I "hover" over the text in the Text/HTML module to edit the text the toolbar (pencil icon) appears near the "Page Functions" at the top of the page near the Control Panel instead of near the Title Bar of the Text/HTML module.
Do you know what might be causing this?
Kevin
07 May 2007 5:09 AM
Hi Kevin,
Yes I just checked this out and I can see the same error, I'm not sure what is causing this.  You can however remove the inline editing options:
Go to the admin menu / site settings
advanced settings / usability settings
Untick inline editor enabled
scroll down, click on update
Forums > Users Lounge > DNN Creative Articles > Red Leaf CSS Skin
