Subject: 4.5.1 Wizard Installation Video (Local)
postrooms
21 Apr 2007 1:54 AM
I would love to see you produce a video building a local install using VWD and SQL 5005 express. There are some dated videos out there that don't really get the job done. Install is one of the most tedious process for first timers. I think you will get tons of new members for just that video alone!
Sean
21 Apr 2007 2:07 AM
Hi Sean,
Well as it happens, for the next issue so far I have recorded (currently editing):
How to install DotNetNuke 4.5.1 to Windows XP Pro using SQL Server Express and IIS
and
How to install DotNetNuke 4.5.1 to Windows XP Home using SQL Server Express and VWD
Both of them start from a fresh bare bones installation of windows and show you how to actually configure windows and install the programmes from scratch before installing DNN.
 - I recently had a hardware failure on my main computer and had to build a new system and re-install everything and as I was doing this I actually came across problems installing DotNetNuke, it probably took me a few hours to find all of the problems and I thought if I am struggling with this from a fresh install of windows how is everyone else going to deal with this?! - So that's why the vids start right from the very beginning and assume that you do not know anything about asp.net, sql server etc.
I hope it will be useful for everyone out there,
Cheers,
Lee
postrooms
21 Apr 2007 4:15 PM
Lee,
That is the best news my frustrated brain has heard all year…lol
I was wondering what the benefits are of using IIS vs. VWD? I have been using VWD because there was more information out there on set-up. Does anyone see any major benefits to using one over the other?
Sean
22 Apr 2007 3:01 AM
Hi Sean,
I always go for IIS, because it's a single program, whereas with VWD this is a much larger program that will take up more memory etc and will slow down your computer in comparison to IIS. Also, IIS is always running so it's really quick to open a DotNetNuke localhost website, rather than having to load up VWD to access your site. You'll see the differences between the two when the tutorials are released, thanks,
Nilesh
24 Apr 2007 1:02 AM
hi,
      how can i install dotnetnuke while after log in i got code which i run ,got message of completion but from where i will start it to develope an application?
24 Apr 2007 1:58 AM
After installing DNN all you have to do is navigate to the localhost address that you specified when you installed DotNetNuke. If you are looking to develop modules have a look at:
http://adefwebserver.com/DotNetNukeHELP/DNN4_DevelopmentEnvironment_noIIS/
The methods vary though depending on the programmes you have installed on your computer, in the next few days the video tutorials will be released on how to install DNN
27 Apr 2007 10:41 AM
Issue 20 is released, complete with the various installation tutorials:
Issue 20 – Installing DotNetNuke 4.5 and XHTML Compliance
Hope you find it useful,
Lee
KMOwen
27 Apr 2007 6:39 PM
Hi Lee
ISSUE 20
The 3rd Video in the XP Pro (IIS) Install appears to be corrupted. The audio is OK but after the initial "DNN Creative" splash screen no video is displayed.
I tried downloading the individual video as well and that had the same problem.
Cheers
28 Apr 2007 3:24 AM
Thanks for the info. - That's odd, if you open the flash file using the htm file it stops after the splash screen but if you click on the flash file direct it plays the entire video.
I will repackage it and upload it - just glad I haven't emailed everyone yet and let them know issue 20 is released!
Lee
28 Apr 2007 3:31 AM
Nilesh, please can you respond directly in the forum as I can't reply to mod alerts, they are to inform me of abuse on the forum:
Thanx Sir, But i have not remembered what was my port number.i again run whole application got this port no with microsoft visual studio 2005 http://localhost:3118/DotNetNuke_04.05.01_Install/Default.aspx. Next day i run again got message "page can not b displayed" i changed in database table this port no and try again but again same msg got.PLEASE tell me wats the solution for microsoft visual studio 2005...
Hallo Sir, should i run whole code ,which i installed from dotnetnuke site , again and again to develope an application.how will i make more application or website using same code(I have run all package codes on my system .i m working on "installation package")
If you are looking to do module development all you need to do is install the 'install' version of DotNetNuke - follow this tutorial:
How to install DotNetNuke 4.5 to Windows XP Pro with IIS
and then you create your modules - check the Michael Washington module development tutorials for this. - Have a look at:
If you wish to edit the core code of DNN then you need to install the source code version. - You will need to understand the methods outlined in
before following:
How to install DotNetNuke 4.5 Source Code to Windows XP Professional
28 Apr 2007 3:54 AM
ok, video 3 is now fixed. - It's uploaded to the tutorial page and I'm currently re-uploading the main issue zips - it will be an hour before that is complete, I will take off those downloads until it's complete,
Lee
28 Apr 2007 5:37 AM
Issue zips are now uploaded and complete, thanks
nilesh k
30 Apr 2007 1:09 AM
hallo,
i opend this link "How to install DotNetNuke 4.5 to Windows XP Pro with IIS" but got nothing Video there.well when i run code after installation from dotNetNuke site i worked on this URL " http://localhost:3118/DotNetNuke_04.05.01_Install/Default.aspx " after shut down Computer Next day i run same URL but got error message "Page can't be displayed" i changed in database table "PortAlias" a field HTTPAlias valus as "localhost:3118/DotNetNuke_04.05.01_Install" and again run and again got "page can't be displayed" please what is solution.all thing i did with Visual studio development 2005 ,SQLEXPRESS 2005
30 Apr 2007 3:33 AM
Hi Nilesh,
You need to subscribe to view and download the videos.
It looks as though you are using the web server from visual studio rather than using IIS, if you are using the visual studio web server you will need to run visual studio in order to run your DNN website. If you have windows XP pro it's best to setup DNN using IIS.
nilesh k
30 Apr 2007 4:51 AM
Thanx Lee,
                    i am unable to understand this --> "you will need to run visual studio in order to run your DNN website." how to run Visual studio while after installation all code i run it in visual studio got link http://localhost:3118/DotNetNuke_04.05.01_Install/Default.aspx shut down My computer next day opend same link to work on my last day's work but got messag"Page can not b displayed" DNS server Error.please Help me Sir...........
30 Apr 2007 5:01 AM
If you have setup DotNetNuke using the web server from visual studio then you will need to start the web server from visual studio in order to run DotNetNuke.
Whereas if you set up DotNetNuke using IIS then you can just enter the local host installation address and it will load up without having to open additional programmes.
nilesh k
01 May 2007 7:40 AM
Thnx Lee,
                    i have installed successfuly DotNetNuke 4.5.1 Run project without debugging mode as instructions i got this below errors how to remove it.i am using ExpressEdition 2005, SqlExpress---->
Warning 1 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 6 28 d:\NukeFolder\DotNetNuke Website1\
Warning 2 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 7 31 d:\NukeFolder\DotNetNuke Website1\
Warning 3 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 8 34 d:\NukeFolder\DotNetNuke Website1\
Warning 4 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 9 34 d:\NukeFolder\DotNetNuke Website1\
Warning 5 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 10 41 d:\NukeFolder\DotNetNuke Website1\
Warning 6 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 11 35 d:\NukeFolder\DotNetNuke Website1\
Warning 7 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 12 39 d:\NukeFolder\DotNetNuke Website1\
Warning 8 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 13 35 d:\NukeFolder\DotNetNuke Website1\
Warning 9 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 14 31 d:\NukeFolder\DotNetNuke Website1\
Warning 10 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 15 38 d:\NukeFolder\DotNetNuke Website1\
Warning 11 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 16 31 d:\NukeFolder\DotNetNuke Website1\
Warning 12 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 17 29 d:\NukeFolder\DotNetNuke Website1\
Warning 13 The 'requirePermission' attribute is not declared. d:\NukeFolder\DotNetNuke Website1\web.config 18 32 d:\NukeFolder\DotNetNuke Website1\
Message 14 Could not find schema information for the element 'compilers'. d:\NukeFolder\DotNetNuke Website1\web.config 52 6 d:\NukeFolder\DotNetNuke Website1\
Message 15 Could not find schema information for the element 'compiler'. d:\NukeFolder\DotNetNuke Website1\web.config 53 8 d:\NukeFolder\DotNetNuke Website1\
Message 16 Could not find schema information for the attribute 'language'. d:\NukeFolder\DotNetNuke Website1\web.config 54 9 d:\NukeFolder\DotNetNuke Website1\
Message 17 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 55 9 d:\NukeFolder\DotNetNuke Website1\
Message 18 Could not find schema information for the attribute 'extension'. d:\NukeFolder\DotNetNuke Website1\web.config 56 9 d:\NukeFolder\DotNetNuke Website1\
Message 19 Could not find schema information for the element 'dotnetnuke'. d:\NukeFolder\DotNetNuke Website1\web.config 224 4 d:\NukeFolder\DotNetNuke Website1\
Message 20 Could not find schema information for the element 'htmlEditor'. d:\NukeFolder\DotNetNuke Website1\web.config 225 6 d:\NukeFolder\DotNetNuke Website1\
Message 21 Could not find schema information for the attribute 'defaultProvider'. d:\NukeFolder\DotNetNuke Website1\web.config 226 7 d:\NukeFolder\DotNetNuke Website1\
Message 22 Could not find schema information for the element 'providers'. d:\NukeFolder\DotNetNuke Website1\web.config 227 8 d:\NukeFolder\DotNetNuke Website1\
Message 23 Could not find schema information for the element 'clear'. d:\NukeFolder\DotNetNuke Website1\web.config 228 10 d:\NukeFolder\DotNetNuke Website1\
Message 24 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 229 13 d:\NukeFolder\DotNetNuke Website1\
Message 25 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 229 17 d:\NukeFolder\DotNetNuke Website1\
Message 26 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 230 6 d:\NukeFolder\DotNetNuke Website1\
Message 27 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 231 6 d:\NukeFolder\DotNetNuke Website1\
Message 28 Could not find schema information for the attribute 'CustomConfigurationPath'. d:\NukeFolder\DotNetNuke Website1\web.config 232 6 d:\NukeFolder\DotNetNuke Website1\
Message 29 Could not find schema information for the attribute 'EnhancedSecurityDefault'. d:\NukeFolder\DotNetNuke Website1\web.config 233 6 d:\NukeFolder\DotNetNuke Website1\
Message 30 Could not find schema information for the attribute 'SecureConfigurationPath'. d:\NukeFolder\DotNetNuke Website1\web.config 234 6 d:\NukeFolder\DotNetNuke Website1\
Message 31 Could not find schema information for the attribute 'ImageGalleryPath'. d:\NukeFolder\DotNetNuke Website1\web.config 235 6 d:\NukeFolder\DotNetNuke Website1\
Message 32 Could not find schema information for the attribute 'ImageUploadPath'. d:\NukeFolder\DotNetNuke Website1\web.config 236 6 d:\NukeFolder\DotNetNuke Website1\
Message 33 Could not find schema information for the attribute 'ImageAllowedFileTypes'. d:\NukeFolder\DotNetNuke Website1\web.config 237 6 d:\NukeFolder\DotNetNuke Website1\
Message 34 Could not find schema information for the attribute 'FlashGalleryPath'. d:\NukeFolder\DotNetNuke Website1\web.config 238 6 d:\NukeFolder\DotNetNuke Website1\
Message 35 Could not find schema information for the attribute 'FlashUploadPath'. d:\NukeFolder\DotNetNuke Website1\web.config 239 6 d:\NukeFolder\DotNetNuke Website1\
Message 36 Could not find schema information for the attribute 'FlashAllowedFileTypes'. d:\NukeFolder\DotNetNuke Website1\web.config 240 6 d:\NukeFolder\DotNetNuke Website1\
Message 37 Could not find schema information for the attribute 'LinksGalleryPath'. d:\NukeFolder\DotNetNuke Website1\web.config 241 6 d:\NukeFolder\DotNetNuke Website1\
Message 38 Could not find schema information for the attribute 'DynamicStylesGeneratorPath'. d:\NukeFolder\DotNetNuke Website1\web.config 242 6 d:\NukeFolder\DotNetNuke Website1\
Message 39 Could not find schema information for the attribute 'DynamicStylesCaseSensitive'. d:\NukeFolder\DotNetNuke Website1\web.config 243 6 d:\NukeFolder\DotNetNuke Website1\
Message 40 Could not find schema information for the attribute 'DynamicStylesGeneratorFilter'. d:\NukeFolder\DotNetNuke Website1\web.config 244 6 d:\NukeFolder\DotNetNuke Website1\
Message 41 Could not find schema information for the attribute 'StaticStylesFile'. d:\NukeFolder\DotNetNuke Website1\web.config 245 6 d:\NukeFolder\DotNetNuke Website1\
Message 42 Could not find schema information for the attribute 'StylesDefaultMode'. d:\NukeFolder\DotNetNuke Website1\web.config 246 6 d:\NukeFolder\DotNetNuke Website1\
Message 43 Could not find schema information for the attribute 'DynamicCSSGeneratorPath'. d:\NukeFolder\DotNetNuke Website1\web.config 247 6 d:\NukeFolder\DotNetNuke Website1\
Message 44 Could not find schema information for the attribute 'StaticCSSFile'. d:\NukeFolder\DotNetNuke Website1\web.config 248 6 d:\NukeFolder\DotNetNuke Website1\
Message 45 Could not find schema information for the attribute 'CSSDefaultMode'. d:\NukeFolder\DotNetNuke Website1\web.config 249 6 d:\NukeFolder\DotNetNuke Website1\
Message 46 Could not find schema information for the attribute 'spellCheck'. d:\NukeFolder\DotNetNuke Website1\web.config 250 6 d:\NukeFolder\DotNetNuke Website1\
Message 47 Could not find schema information for the attribute 'AvailableToolbarSkins'. d:\NukeFolder\DotNetNuke Website1\web.config 251 6 d:\NukeFolder\DotNetNuke Website1\
Message 48 Could not find schema information for the attribute 'DefaultToolbarSkin'. d:\NukeFolder\DotNetNuke Website1\web.config 252 6 d:\NukeFolder\DotNetNuke Website1\
Message 49 Could not find schema information for the attribute 'AvailableToolBarSets'. d:\NukeFolder\DotNetNuke Website1\web.config 253 6 d:\NukeFolder\DotNetNuke Website1\
Message 50 Could not find schema information for the attribute 'DefaultToolbarSet'. d:\NukeFolder\DotNetNuke Website1\web.config 254 6 d:\NukeFolder\DotNetNuke Website1\
Message 51 Could not find schema information for the attribute 'DefaultImageGallerySkin'. d:\NukeFolder\DotNetNuke Website1\web.config 255 6 d:\NukeFolder\DotNetNuke Website1\
Message 52 Could not find schema information for the attribute 'DefaultFlashGallerySkin'. d:\NukeFolder\DotNetNuke Website1\web.config 256 6 d:\NukeFolder\DotNetNuke Website1\
Message 53 Could not find schema information for the attribute 'DefaultLinksGallerySkin'. d:\NukeFolder\DotNetNuke Website1\web.config 257 6 d:\NukeFolder\DotNetNuke Website1\
Message 54 Could not find schema information for the attribute 'FCKDebugMode'. d:\NukeFolder\DotNetNuke Website1\web.config 258 6 d:\NukeFolder\DotNetNuke Website1\
Message 55 Could not find schema information for the attribute 'UseFCKSource'. d:\NukeFolder\DotNetNuke Website1\web.config 259 6 d:\NukeFolder\DotNetNuke Website1\
Message 56 Could not find schema information for the attribute 'OptionsOpenMode'. d:\NukeFolder\DotNetNuke Website1\web.config 260 6 d:\NukeFolder\DotNetNuke Website1\
Message 57 Could not find schema information for the attribute 'CustomOptionsDialog'. d:\NukeFolder\DotNetNuke Website1\web.config 261 6 d:\NukeFolder\DotNetNuke Website1\
Message 58 Could not find schema information for the element 'navigationControl'. d:\NukeFolder\DotNetNuke Website1\web.config 264 6 d:\NukeFolder\DotNetNuke Website1\
Message 59 Could not find schema information for the attribute 'defaultProvider'. d:\NukeFolder\DotNetNuke Website1\web.config 265 7 d:\NukeFolder\DotNetNuke Website1\
Message 60 Could not find schema information for the element 'providers'. d:\NukeFolder\DotNetNuke Website1\web.config 266 8 d:\NukeFolder\DotNetNuke Website1\
Message 61 Could not find schema information for the element 'clear'. d:\NukeFolder\DotNetNuke Website1\web.config 267 10 d:\NukeFolder\DotNetNuke Website1\
Message 62 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 268 10 d:\NukeFolder\DotNetNuke Website1\
Message 63 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 269 11 d:\NukeFolder\DotNetNuke Website1\
Message 64 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 270 11 d:\NukeFolder\DotNetNuke Website1\
Message 65 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 271 11 d:\NukeFolder\DotNetNuke Website1\
Message 66 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 272 10 d:\NukeFolder\DotNetNuke Website1\
Message 67 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 273 11 d:\NukeFolder\DotNetNuke Website1\
Message 68 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 274 11 d:\NukeFolder\DotNetNuke Website1\
Message 69 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 275 11 d:\NukeFolder\DotNetNuke Website1\
Message 70 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 276 10 d:\NukeFolder\DotNetNuke Website1\
Message 71 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 277 11 d:\NukeFolder\DotNetNuke Website1\
Message 72 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 278 11 d:\NukeFolder\DotNetNuke Website1\
Message 73 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 279 11 d:\NukeFolder\DotNetNuke Website1\
Message 74 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 280 10 d:\NukeFolder\DotNetNuke Website1\
Message 75 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 281 11 d:\NukeFolder\DotNetNuke Website1\
Message 76 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 282 11 d:\NukeFolder\DotNetNuke Website1\
Message 77 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 283 11 d:\NukeFolder\DotNetNuke Website1\
Message 78 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 284 10 d:\NukeFolder\DotNetNuke Website1\
Message 79 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 285 11 d:\NukeFolder\DotNetNuke Website1\
Message 80 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 286 11 d:\NukeFolder\DotNetNuke Website1\
Message 81 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 287 11 d:\NukeFolder\DotNetNuke Website1\
Message 82 Could not find schema information for the element 'searchIndex'. d:\NukeFolder\DotNetNuke Website1\web.config 290 6 d:\NukeFolder\DotNetNuke Website1\
Message 83 Could not find schema information for the attribute 'defaultProvider'. d:\NukeFolder\DotNetNuke Website1\web.config 291 7 d:\NukeFolder\DotNetNuke Website1\
Message 84 Could not find schema information for the element 'providers'. d:\NukeFolder\DotNetNuke Website1\web.config 292 8 d:\NukeFolder\DotNetNuke Website1\
Message 85 Could not find schema information for the element 'clear'. d:\NukeFolder\DotNetNuke Website1\web.config 293 10 d:\NukeFolder\DotNetNuke Website1\
Message 86 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 294 10 d:\NukeFolder\DotNetNuke Website1\
Message 87 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 295 11 d:\NukeFolder\DotNetNuke Website1\
Message 88 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 296 11 d:\NukeFolder\DotNetNuke Website1\
Message 89 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 297 11 d:\NukeFolder\DotNetNuke Website1\
Message 90 Could not find schema information for the element 'searchDataStore'. d:\NukeFolder\DotNetNuke Website1\web.config 300 6 d:\NukeFolder\DotNetNuke Website1\
Message 91 Could not find schema information for the attribute 'defaultProvider'. d:\NukeFolder\DotNetNuke Website1\web.config 301 7 d:\NukeFolder\DotNetNuke Website1\
Message 92 Could not find schema information for the element 'providers'. d:\NukeFolder\DotNetNuke Website1\web.config 302 8 d:\NukeFolder\DotNetNuke Website1\
Message 93 Could not find schema information for the element 'clear'. d:\NukeFolder\DotNetNuke Website1\web.config 303 10 d:\NukeFolder\DotNetNuke Website1\
Message 94 Could not find schema information for the element 'add'. d:\NukeFolder\DotNetNuke Website1\web.config 304 10 d:\NukeFolder\DotNetNuke Website1\
Message 95 Could not find schema information for the attribute 'name'. d:\NukeFolder\DotNetNuke Website1\web.config 305 11 d:\NukeFolder\DotNetNuke Website1\
Message 96 Could not find schema information for the attribute 'type'. d:\NukeFolder\DotNetNuke Website1\web.config 306 11 d:\NukeFolder\DotNetNuke Website1\
Message 97 Could not find schema information for the attribute 'providerPath'. d:\NukeFolder\DotNetNuke Website1\web.config 307 11 d:\NukeFolder\DotNetNuke Website1\
Message 98 Could not find schema information for the element 'data'. d:\NukeFolder\DotNetNuke Website1\web.config 310 6 d:\NukeFolder\DotNetNuke Website1\
Message 99 Could not find schema information for the attribute 'defaultProvider'. d:\NukeFolder\DotNetNuke Website1\web.config 311 7 d:\NukeFolder\DotNetNuke Website1\
Message 100 Could not find schema information for the element 'providers'. d:\NukeFolder\DotNetNuke Website1\web.config 312 8 d:\NukeFolder\DotNetNuke Website1\
Warning 101 The maximum number of errors or warnings has been reached. d:\NukeFolder\DotNetNuke Website1\web.config 411 1 d:\NukeFolder\DotNetNuke Website1\
Error 102 The files '/DotNetNuke Website1/App_Code/Widget/DataProvider.cs' and '/DotNetNuke Website1/App_Code/AssemblyInfo.vb' use a different language, which is not allowed since they need to be compiled together. /
01 May 2007 8:14 AM
Hi nilesh,
Before attempting to install DNN source code I recommend you try to install the install version so that you understand the concepts and that everything is working correctly. - Have you followed this video:
  • How to install DotNetNuke 4.5 to Windows XP Pro with IIS
  • before looking at this video:
  • How to install DotNetNuke 4.5 Source Code to Windows XP Professional
  • If you go through this video step by step you should be able to install without errors:
    If you have already gone through the video, outline which steps you have taken in the video and I then maybe able to help.
    nilesh k
    02 May 2007 5:11 AM
    in C:\ drive my application is name is dotnetnukewebsite11 on right click it there is  security tab a button "Add" clicking on it it ask "Enter the object name to select " what name i should give in win XP SP2 IE 6.0.for win 2003 it is ASPNET like this what name would b for  win XP SP2 IE 6.0 i made an project using http file--> http:\\localhost\dotnetnukewebsite11
    03 May 2007 2:16 AM
    click add
    click advanced
    click find now
    select ASP.NET account
    click ok
    click ok
    tick full control
    postrooms
    07 May 2007 2:29 AM
    Lee,
    We followed your instructions and when it comes to installing SQL Server 2005, the screens don’t match after the feature selection.
    Instance name appears with two options:
    1. Default Instance
    2. Named Instance – Labeled SQLExpress (Default Selection)
    We selected the default and moved on.
    Next when we to Report Server Installation options
    • Both choices are grayed out and install but do not configure the server is selected.
    We click next and the install completes O.K.
    I log into my site and start to build. After I restart my PC, I can not get the site to start again.
    I log into IS and the Default Web Site folder has an error stop sign and says (Stopped). I have tried several things toget it back up again with no luck….Any suggestions?
    Thank you,
    Sean
    07 May 2007 4:01 AM
    This sounds like a problem with IIS rather than SQL Server. The differences in the screens for installing SQL server may have happened if you installed a different version - if you recall I installed the advanced version of SQL Server express, rather than the version that will be automatically installed when you install visual web developer express.
    I have come across this problem and it's due to another programme using the resources that IIS needs, I can't remember how I fixed it but I found the solution by looking through the Microsoft.com help website (try restarting IIS (right click on Default website and select start) and follow the error links that it produces)
    - Sometimes the problem reoccurs for no reason on my system as well and recently I've found the best solution is to use virtual server 2005 or virtual pc 2007 (both are free downloads from Microsoft). -  This allows you to set up several test areas and is ideal for moving test systems from one computer to another.  So I now literally have operating systems set up with just the minimal programs installed for running DotNetNuke and I have no problems with other programmes causing conflicts.
    If you do not want to go down the virtual route (I highly recommend you try it ;-) )  I would attempt to look at disabling programs starting up on startup of windows (go through them one at a time to see if you can find the culprit), restart Windows and see if it allows you to restart IIS. - (right click on Default website and select start)
    Hope this helps,
    KMOwen
    07 May 2007 5:04 AM
    Lee / Sean
    When installing SQL Server Express 2005 I also received the following options.....
    1. Default Instance
    I worked out that the reason for this was that I already had an instance of SQL Server Express 2005 already installed. I also found that unless you follow the exact sequence for installing each of the applications (as per Lee's videos in Issue 20) you might also have some issues with the ASP.NET account not registering correctly and unavailable in the list of installed "users". This happened because I installed IIS AFTER the .NET Framework....
    My advice if you are having problems installing DNN on XP Pro with IIS (which is what I ended up doing) is to uninstall SQL Server Express including all other SQL components and the NET Framework Ver 2.0 via Add or Remove Programs in the Control Panel. I also uninstalled IIS via Add/Remove Windows components, again via the Control Panel.
    I then followed Lee's Videos "Step by Step" and installed (1) IIS (2) .NET Framework (3) SQL Server Express (4) DotNetNuke. Everything worked identically to how Lee explained it in the videos and worked first time....
    Hope this helps
    Kevin
    07 May 2007 5:13 AM
    Hi Kevin,
    Thanks, that's a good tip. - I also came across problems installing DotNetNuke when I had to install it to a new computer - the problems were caused by installing programmes in a different order to the way I installed on the videos and IE7 changing intranet security settings - if you follow the steps exactly you should be ok.
    postrooms
    07 May 2007 8:51 PM
    Kevin,
    Thanks for the tip; I was removing everything except ASP.NET. I will wipe it clean and start over.
    Has anyone tried local development on Vista? We are thinking of upgrading equipment and Vista will no doubt come standard.
    Thank you,
    Sean
    08 May 2007 3:23 AM
    I haven't tried Vista yet - I do seem to recall reading a blog post about it though - I would google and you will probably come across something. - The security and IIS will be slightly different but you should be able to work it out once you have successfully figured it out on XP - if there is a demand for it I will create a tutorial for Vista.
    postrooms
    09 May 2007 2:38 AM
    Lee,
    I started with a fresh install and I'm back in business :o) I think a Vista video would be a great addition to the collection. As much as I am not in love with Vista yet, I am ready to upgrade my equipment and like most people buying a new PC, you are going to have to upgrade or pay to re-install XP.
    Sean
    Terp
    11 May 2007 8:18 PM
    If I only use SQL on my laptop for DNN, would it be best to d/l and install the 'express' version, or my full version of SQL 2005? Would downgrading to the express improve performance?
    If I am using a regular SQL database with my host, will there me any issues? ...never used the express version and thought that perhaps it limits you to MySQL databases with your host....no idea what is best.
    Any suggestions welcome!
    Priceline Bid Database
    GoDaddy Coupons | GoDaddy Codes | GoDaddy Deals!
    American Idol Fanclub!
    14 May 2007 4:23 AM
    If you have the full version I would personally install that. - It will make it much easier for development and maintaining databases between localhost and the live site in the future. Thanks,
    Forums > Users Lounge > DNN Creative Articles > 4.5.1 Wizard Installation Video (Local)
