Subject: Is there any tutorial/article on DNN performance tunning?
puremood_2002
13 Apr 2007 3:46 PM
I think I saw it somewhere but can't find it any more. Could anyone tell me? thanks a lot!
16 Apr 2007 9:24 AM
John Mitchel made a post in his blog regarding the performance settings:
http://blogs.snapsis.com/PermaLink,guid,c0415290-f6e3-41ea-aef6-ef34728a8ef0.aspx
we discussed this here: DotNetNuke Performance
Forums > Users Lounge > DNN Creative Articles > Is there any tutorial/article on DNN performance tunning?
