Subject: LocalHost a portal
pdqjohnny
19 Jan 2007 3:24 PM
Hi;
I have a DNN Website up and running. I have an inhouse server doing it. I want  to get it on a different computer for trying different modules on it while not messing up the live Website.
I reviewed you tutorail on Portal Alias but I do not think that is what I'm in need of. I assume I have to backup my site to my LocalHost computer and reinstall it in my computer's Inetpub  directory and into a MySQL installation on my machine. If that is possible?
I hope this is clear enough. Maybe VS2006 has an easy way to do this, Any suggestions.
pdqjohnny
20 Jan 2007 3:42 AM
Have a read of this post here where I outlined transferring data from a live website to a localhost site, you should be able to adapt this to your setup:
http://www.dnncreative.com/Forum/tabid/88/forumid/Forum/tabid/88/view/topic/forumid/4/postid/1919/Default.aspx
Also have a read of:
http://www.dnncreative.com/Forum/tabid/88/forumid/12/postid/47/view/topic/Default.aspx
Hope this helps,
Forums > Users Lounge > DNN Creative Articles > LocalHost a portal
Skim Question by tlsadler
