Subject: Issue 17 DonetNuke Portals
DavidWSnow
10 Jan 2007 1:59 PM
Really Good - Thanks - and it was very timely for me.
Comments:
The DNS stuff differs greatly from ISP to ISP. I had been unable to get a parent portal to work there before. Their basic setup for what they call a subdirectory is actually "domain forwarding". When I setup sample.agingsafely.com  and went to DNSstuff to look at the records they weren't there.
When I looked back at GD's domain display I saw that sample was pointing to a different IP than AgingSafely.com.   I was able to edit this A Record to point to my server rather than a seperate service that GD uses for redirection. All was good after about 20 minutes.
The comment in Lee's video about the directory required for child portal, saved me in two ways. First it turns out that my backup tool wasn't saving that directory. Second at GD woth DNN hosted at the root I would have to hand create these directories, since GD doesn't give ASPNET write privs on that directory.
Again - Great Job Lee
Forums > Users Lounge > DNN Creative Articles > Issue 17 DonetNuke Portals
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
RE: Query regarding clearing cache by jncraig
Query regarding clearing cache by kaustav_kar
Hi,In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the he...
MY FIRST DNN SITE by mattshortland
hello I am just working on my first dnn site and wondered what you all think? http://letcombebass...
New CSS site feedback please! by dp6ai
I've just designed my first CSS site. I'm not sure how well it works because the client was so keen ...
