Subject: Compact Register Control
egarret
11 Dec 2006 1:05 AM
I have been enjoying your tutorials and modified the Register control to require Address etc and put them all under a "Details" category.
Your Register control is a nice compact 2 column version.  How can I do that??
garret
11 Dec 2006 2:41 AM
Currently the site is still using DNN v3.2.2 which uses a different register page and functions. In the latest version of 4.3.x you can't display the register page in a 2 column version.
Forums > Users Lounge > DNN Creative Articles > Compact Register Control
Skim Question by tlsadler
