Subject: Making it Cool - Creating a Mashup in Open Web Studio - Part 6 of 6 - Issue 48
01 Sep 2009 12:42 PM
Add any comments or questions regarding the Making it Cool - Creating a Mashup - Part 6 of 6 – How to Build a Public Knowledge Base with OWS tutorial from issue 48
Mark Stouffer
03 Mar 2010 5:00 PM
Lee, I am having trouble finding documentation on how to form the parsing statement in a RESTfull API call. Currently I am using Ebay and I need to pull the fields from the nodes in the data below. I had to use JSON instead of XML but it looks like the path is specified the same way. I will be looking at the findItemsByCategoryResponse>searchResult>item. I will be reading about five fields from the item node. How do I specify the fields in the item node?
{"findItemsByCategoryResponse":[
{"ack":["Success"],"version":["1.3.0"],"timestamp":["2010-03-03T23:15:43.117Z"],
"searchResult":[{"@count":"2","item":[
{"itemId":["250534186469"],
" le":["Intermediate level A major Chinese flute\/ xiao\/ Beixiao"],
"globalId":["EBAY-US"],"primaryCategory":[{"categoryId":["10183"],"categoryName":["Flute"]}],
"galleryURL":["http:\/\/thumbs2.ebaystatic.com\/pict\/2505341864698080_8.jpg"],
"viewItemURL":["http:\/\/cgi.ebay.com\/Intermediate-level-A-major-Chinese-flute-xiao-Beixiao_W0QQitemZ250534186469QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a55004de5"],
"paymentMethod":["PayPal"],
"autoPay":["false"],
"location":["Hong Kong"],
"country":["HK"],
"shippingInfo":[{"shippingServiceCost":[{"@currencyId":"USD","__value__":"12.0"}],
"shippingType":["Flat"],"shipToLocations":["Worldwide"]}],
"sellingStatus":[{"currentPrice":[{"@currencyId":"USD","__value__":"21.0"}],"convertedCurrentPrice":[{"@currencyId":"USD","__value__":"21.0"}],"sellingState":["Active"],"timeLeft":["P17DT2H41M58S"]}],"listingInfo":[{"bestOfferEnabled":["false"],"buyItNowAvailable":["false"],"startTime":["2009-11-21T01:52:41.000Z"],"endTime":["2010-03-21T01:57:41.000Z"],"listingType":["FixedPrice"],"gift":["false"]}]},
{"itemId":["170451948724"],
" le":["Wooden tenor recorder Schreiber w\/carry case"],
"globalId":["EBAY-US"],"primaryCategory":[{"categoryId":["16230"],"categoryName":["Recorder"]}],
"galleryURL":["http:\/\/thumbs1.ebaystatic.com\/pict\/1704519487248080_1.jpg"],
"viewItemURL":["http:\/\/cgi.ebay.com\/Wooden-tenor-recorder-Schreiber-w-carry-case_W0QQitemZ170451948724QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27afba54b4"],
"paymentMethod":["PayPal"],"autoPay":["false"],"postalCode":["30359"],"location":["Atlanta,GA,USA"],"country":["US"],"shippingInfo":[{"shippingType":["Calculated"],"shipToLocations":["US"]}],"sellingStatus":[{"currentPrice":[{"@currencyId":"USD","__value__":"52.0"}],"convertedCurrentPrice":[{"@currencyId":"USD","__value__":"52.0"}],"bidCount":["8"],"sellingState":["Active"],"timeLeft":["P0DT0H2M21S"]}],"listingInfo":[{"bestOfferEnabled":["false"],"buyItNowAvailable":["false"],"startTime":["2010-02-26T23:18:04.000Z"],"endTime":["2010-03-03T23:18:04.000Z"],"listingType":["Auction"],"gift":["false"]}]}]}],"paginationOutput":[{"pageNumber":["1"],"entriesPerPage":["2"],"totalPages":["7816"],"totalEntries":["15632"]}]}]}
Forums > Users Lounge > DNN Creative Articles > Making it Cool - Creating a Mashup in Open Web Studio - Part 6 of 6 - Issue 48
RE: Server Error in '/' Application. by michellb
Here is the entire text on the page: Server Error in '/' Application. Runtime Error Descrip...
No, I still don't have a solution for this
