Subject: Adding developer toolbar to firefox
cipher2079
18 Oct 2006 11:13 AM
hi lee,
I've being trying to download and install the css developer toolbar
which you have used in issue 12 how to create a horizantal menu
is there anyway you give the full name of this application and some tips
how to make work
I did download a similar version though I don't think is the same one
18 Oct 2006 11:30 AM
You can download the toolbar from:
http://chrispederick.com/work/webdeveloper/
I was thinking about creating a video on quick tips for using the toolbar for creating and troubleshooting skins in DNN.
Is this something you would find useful?
cipher2079
18 Oct 2006 12:50 PM
I personally think it would be a great advantage for both party
first it would make things much easier for the developer
second programming in css would become clearer
in the sense of margin, padding, colors, attribute, ect...
however, I think a written tutorial would do just about the trick
unless if there more to it then just downloading and installing
which I am not sure i have not tried it yet.............
cipher2079
18 Oct 2006 12:52 PM
oh............for quick tips
that will be great
sorry excitement kick in
01 Nov 2006 9:07 AM
Just to let you know, I didn't have time to complete the video for issue 15, but I have recorded the tutorial, I've just got to edit the 4 videos that I created. - Will probably be 2 videos by the time I have edited them. - I will work on them first of all for issue 16 and give you access to the videos before issue 16 is released.
06 Nov 2006 11:14 AM
ok, I've put together the video for you covering troubleshooting skins, it will be officially released in issue 16 - Dec - but here is the link to the page ;-)
Troubleshooting DotNetNuke skins using the web developer toolbar
Hope you find it useful,
Forums > Users Lounge > DNN Creative Articles > Adding developer toolbar to firefox
