Subject: problems adding adsense
cipher2079
15 Oct 2006 10:08 AM
Hi lee,
I am currently working on issue 12 incorporating google adsense
I follow the tutorial step, however I ran into a problem while
Placing the adsense on certain places
The left side is working properly however the right side
And the redleaf box aren’t
The adsense does appear but not on the right hand side but at the top
Of the text, this also occurs with the readleaf box container which does
Appear but not on the left nor the right but on top of the text.
note that I have added some of the features from issue 9
How to build a website on tutorial11, 12 styling text images, formatting
Dealing with the fckeditor
To faster implement the images, quotes, and captions
I think this might be interfering with the adsense though I am not sure.
Here are the step I’ve taken:
  1. create html container file with google adsense code
  2. declared and entered the details for class and appropriate float detail.
  3. uploaded container
cipher2079
15 Oct 2006 10:42 AM
ok...now I got the right adsense working I think it had to do with the way I set up the files and folders
I am now going to make these same changes on the readleaf box files
cipher2079
15 Oct 2006 11:19 AM
ok everything is working correctly
I think that having to many file in my _default container folder with the same files but different name
of the parent folder (kind of similar too) made things a little to complicated
so i decided to get rid of some of the folders and changed the names of the folders that
were not delete. thus i think that the dilemma had to do with the url or the names of the folder
since there were all so alike....is hard to explain......but once _default folder was organized
and the names were changed everything started to work.
16 Oct 2006 3:46 AM
Glad to hear you got it working. When testing out new techniques I always start with a basic skin, such as the basic version of the red leaf skin with none of the additional features - this makes it easier to test and find any problems / mistakes that I may have made.
Once I have understood how it works, I then implement it into a more complex skin.
Cheers,
Lee
cipher2079
16 Oct 2006 9:00 AM
Thanks lee I’ve always appreciated your concern
And your professional advice, you’re doing a great job
A+++
cipher2079
16 Oct 2006 9:25 AM
I agree, it is something that I had to learn the hard way
I actually start with read leaf version from previous tutorial
Which made things more complicated.
Base on my research and analyses (trial and error) I decided to
Use the original container leaf located on this page:
 which has no addition declaration and method
my conclusion is exactly what you mention
start from scratch and work your self up.
Eventually the practicality or practice will educate
And implant the knowledge to your memory
Thus, progression will take place
Forums > Users Lounge > DNN Creative Articles > problems adding adsense
Skim Question by tlsadler
