Subject: Personalization, Text Editor, Logging and Reporting in Open Web Studio - Part 4 of 6 - issue 46
29 Jun 2009 2:38 PM
Add any comments or questions regarding the Personalization, Text Editor, Logging and Reporting in Open Web Studio - Part 4 of 6 tutorial from issue 46
Dat Huynh
30 Jul 2009 2:54 PM
Hello Lee,
Can you show me what is the configuration look like for the following query to receive parameter from the url?
http://www.mysite.com/OWS.aspx?frmsearch=1
SELECT *
FROM products
WHERE ProdID=@frmsearch
Thank you,
Dat
Paul Deschenes
05 Aug 2009 8:27 AM
Here is a link to an example configuration you can import. Open an OWS administration window, click IMPORT, then copy, paste and save the contents of the txt file in the attached zip file link.
http://dnncreative.advologix.com/querystringsearch.zip
Paul Deschenes
DNN Creative OWS Tutor
Forums > Users Lounge > DNN Creative Articles > Personalization, Text Editor, Logging and Reporting in Open Web Studio - Part 4 of 6 - issue 46
How to do links? by Guy..L
How to close a website while you are working on it by mcmanta
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
Yes, that is the one.
Thanks for the tip. I will let my programmer check it out. This is the module you're referring t...
RE: extending user accounts for membership by jncraig
Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ...
RE: DataSprings Dynamic Forms Demo #20 Question by jncraig
There are some nice examples on the Data Springs site.  The more complicated demos do require some s...
RE: Dynamic Forms Email From User/Pass by jncraig
If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo...
Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates...
