Subject: Issue 32 - Powerful Efficient Techniques for DotNetNuke Administration using SQL
10 Oct 2008 8:01 AM
Hello Lee,
First, let me say that I love your videos and this is my second year with your magazine.
Your instructions are clear, with details and cover all aspects of the subjects you cover.
You saved me a lot of time and I really appreciate it.
I have a problem with
Introduction to SQL Queries with SQL Server Express, DotNetNuke and Vista
I work with Windows XP Pro.
I followed your instructions.
I attached my local DNN484 database to MSSQL Express server.
When I run my local DNN484 I get the following error:
Cannot open user default database. Login failed.
Login failed for user 'USER-2595F5A09E\ASPNET'.
I attached here a screen capture of the error.
Do you know what is wrong? Can you help?
Sincerely,
Nir Petrank
Glad to hear you find the videos useful, it is always good to hear.
This problem may be related to your setup of SQL Server, have you previously installed a localhost installation of DotNetNuke to your computer and successfully got it running?
Your problem that may be related to the server authentication mode, it needs to be set to 'SQL server and Windows authentication' mode rather than 'Windows authentication'
I discussed how to fix this problem in this forum post SQL Server authentication mode
nirpet
10 Oct 2008 10:11 AM
Hello Lee,
I worked with my locallhost DNN installation before I worked with your videos. I checked some DNN modules on this installation. It worked well.
I have checked my MSSQL Server Express authentication and it is already set to "SQL Server and Windows authentication" mode. I restart my MSSQL Server to make sure that the server run in this mode. But I still get:
Login failed for use 'USER-2595F5A09E\ASPNET'.
Pay attention to the fact that this is not the user that I configured in my web.config. This the ASPNET process which run all my local websites. The user I configured in web.config is "nirpet".
Nir
10 Oct 2008 11:43 AM
not sure, could you post you web.config connection string for your local installation? anyone else any ideas?
nirpet
11 Oct 2008 3:29 AM
This is my web.config connection string:
Data Source=.\SQLExpress;Initial Catalog=C:\DOTNETNUKE SITES\DNN484\APP_DATA\DATABASE.MDF;User ID=nirpet;Password=xxxxxxxx
Nir
11 Oct 2008 8:51 AM
Just to double-check: You have edited both connection strings?
nirpet
11 Oct 2008 9:09 AM
I checked it again after I saw your post.
The answer is Yes.
I have edited both connection strings.
Nir
13 Oct 2008 10:05 AM
have you created the username + password access that you specified in the connection string for the database?
Forums > Users Lounge > DNN Creative Articles > Issue 32 - Powerful Efficient Techniques for DotNetNuke Administration using SQL
