Subject: menu in dotnetnuke
aravinthkula
25 Aug 2008 12:01 AM
hi,
I have a menu with name login in my website.
Whenever i used to click that menu it should open in separate page.
help me how to do that.
i am using that  page URL option.but it is opening in same page.i want to be open in different page.
thanks ,
aravinth
28 Aug 2008 3:14 AM
The page URL option does not have the option to open links in a new window, they will always open in the same window.
Forums > Users Lounge > DNN Creative Articles > menu in dotnetnuke
Skim Question by tlsadler
