Subject: CSS skin and pane positioning
dp6ai
30 Apr 2008 9:32 AM
After going through the CSS skin tutorial i thought i'd have a go at creating a css skin from scratch, unfortunately i cannot get two new panes to sit side-by-side or be width of anyhing less than 100%.
I cant link to the site as it is on an internal server but i have included my skin.css and index.html and hope someone can shed some lite on this.
thanks in advance.
dp
Attachment: 1430324259871.zip
dp6ai
30 Apr 2008 10:21 AM
sorry to waste everyones time.
I've sorted it. i needed to place the new panes within another div and style them.
thanks
dp
01 May 2008 4:44 AM
glad to hear you fixed the problem,
Forums > Users Lounge > DNN Creative Articles > CSS skin and pane positioning
RE: Database error by derpir
