Subject: DNN Page Links on Skins
ttrivedi
26 Apr 2008 5:39 AM
I found a problem while having a link on my custom page file. how can i refer to page tabid to navigate my dnn page through anchor tag. so i would like to know what is the best way to doing this.
currently i have written the code like as follow
< a target=_blank href="/dnnportal/Products/tabid/54/Default.aspx
in this i have hard cord this tabid is it possible to get it dynamically ? pelase provide me a better solution doing like this.
28 Apr 2008 6:10 AM
I have not come across a method for dynamically getting a link in the text / HTML module, however if you use the links module, when you create a link there is an option for link type, which allows you to select 'Page (a page on your site)'
Forums > Users Lounge > DNN Creative Articles > DNN Page Links on Skins
Glad you sorted it, thanks,
