Subject: Quirks, Standard Compliance modes and Doc Types?
Dave2003
17 Apr 2008 1:14 AM
I downloaded the Default ASPX file from this tutorial page for the XHTML compliance tutorial but it does not seem to be working with DNN4.8 is there a more recent copy that is compatible as this one does not seem to work.
17 Apr 2008 9:26 AM
Try these tutorials:
I'd also be interested to know what "does not seem to be working" from the other tutorial.
18 Apr 2008 3:47 AM
In version 4.8.x the default.aspx file now only needs a couple of changes, it needs:
< meta http-equiv="Content-Type" content="text/html;charset=utf-8" / >
in the head
and it needs
autocomplete="off" removing from the Form section
all other elements in the default.aspx file are fixed
I have added the file into the download list in:
XHTML Compliant DotNetNuke 4.4 and 4.5 - part 2
For DOC TYPES, they are now specified in the index.doctype.xml file, have a look here:
How to select DOC TYPES in DotNetNuke 4.4
Forums > Users Lounge > DNN Creative Articles > Quirks, Standard Compliance modes and Doc Types?
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
RE: Query regarding clearing cache by jncraig
Query regarding clearing cache by kaustav_kar
Hi,In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the he...
MY FIRST DNN SITE by mattshortland
hello I am just working on my first dnn site and wondered what you all think? http://letcombebass...
New CSS site feedback please! by dp6ai
I've just designed my first CSS site. I'm not sure how well it works because the client was so keen ...
