Display Menu List
Last Post 2008-03-13 02:10 PM by Joseph Craig. 1 Replies.
zooomitUser is Offline
2008-03-13 06:25 AM
Hi All! I need help if any one ... I want to create a module to display menulist on the home page and seperate admin panel for updating dynamically that menu list which I want to keep in a seperate page so that only the admin user can edit and update from a centralize place as we create in .net one admin page and links for all other pages which are dynamically updating ..... can u please tell me how can it possible in DNN
2008-03-13 02:10 PM
The short answer is that you create it just like any other menu or module. You would be able to get the pages from the Tabs database table. You should probably study code from an existing menu module to see how this is done.
Smart-Thinker.com has a "Utilities" module that may have some of the functionality that you need. I don't know all of it's details, but you can take a look.
I'm also interested in why you need to do this. What is missing in the existing functionality that you need?
DNN nav issue by imran shaikh
