variable of username
Last Post 2008-03-13 05:28 AM by meenu. 2 Replies.
meenuUser is Offline
2008-03-12 07:29 AM
dear friends
i am using DNN 04 08 and visual studio 2005
i created a new module in my DNN0408.i installed this module it is working properly.
in my module i have a button.
in that button click  i done this follwing code.my web is coming properly.from here i want to pass my dnn current username also with this link. how?
  Page.ClientScript.RegisterClientScriptBlock(Me.GetType(), "popup", "window.open('http://192.168.151.15:88/webform1.a...tatus=no')", True)
 can anybody help me?
which is the variable available in dnn for current user?
regards
2008-03-12 02:47 PM
The current user's information is available through the DotNetNuke.Entities.Users.UserController class. You will want to get UserInfo.
2008-03-13 05:28 AM
thank u very much for ur support.
i done it.
Dim objUser As UserInfo = UserController.GetCurrentUserInfo
Dim user4mapping As String
user4mapping = objUser.Username
Page.ClientScript.RegisterClientScriptBlock(Me.GetType(), "popup", "window.open('http://192.168.151.15:88/webform1.a...?username=" & user4mapping & "','','scrollbars=no,menubar=no,height=650,width=screen.width,resizable=no,toolbar=no,location=no,status=no')", True)
DNN nav issue by imran shaikh
