Can't login - Accidentally deleted the Login page or Login link
Last Post 2011-06-04 05:13 AM by rubicite. 39 Replies.
Page 2 of 2 << < 12
Joseph CraigUser is Online
2008-07-11 02:00 PM
I've got to believe that there is something going on with IIS that is causing this. Are there any host headers or other things associated with your website?
Is there any chance that you can try doing an install on another computer?
verceUser is Offline
2008-07-11 02:01 PM
Ok, I'll try with it..
thanks.
2008-07-11 02:13 PM
I tried to install it on other computer, but there I get into new problem trought  the installation process. I get an error there that tell my to allow remote connections to the Server, so I did it but I still get the same error.
so I don't know what to do there eider.
And I don't have no other things associated with my website on the both computers.
2008-07-11 10:12 PM
If you can't connect to the server, problems that you might be having could be related to that issue.
2008-07-16 02:57 PM
Hey...
I try on Mozila and it worked
I didn't change anything.
Thanks anyway
LenUser is Offline
2009-05-01 01:51 AM
I got click-happy and accidentallyy set my login page to Home or something. I found John Mitchell's OpenSesame.aspx worked wonders on DNN 4.9.1
http://blogs.snapsis.com/PermaLink,...11906.aspx
bragaruUser is Offline
2009-07-30 09:57 AM
Hello!
it semms I have a problem with the login module that i cannot see in this page:
I try to login, but i have a blank page with no login and pass forms... and I get only a strange image like a blank paper with a lock on it. I tried to use the ctl=... issue but i get the same blank page... Do you have any suggestion?
Thank you!
2009-07-30 10:16 AM
you can see the "no login page" here: http://www.dnn.e-secure.ro/Login.as...fault.aspx
2009-07-30 01:56 PM
It seems that you've fixed the problem!
Taz WilksUser is Offline
2010-01-16 06:58 AM
I know that this is an old thread but the problem can still appear in the latest versions of DNN. It appears that there have been some updates in DNN 5 that stop the following Snapis hint from working: "Also, if you can get access to your DB then you can run a query to fix this problem. Update Portals Set LoginTabId=null Where PortalId=xx" Note that the LoginTabId field is now contained in the PortalLocalization table so the query that needs to be used in DNN5 is: Update PortalLocalization Set LoginTabId=null Where PortalId=xx" I've attached an updated version of John's OpenSesame solution for DNN 5 to this reply. I haven't tested it but it is such a minor change there shouldn't be a problem. Instructions are at his blog link at http://blogs.snapsis.com/PermaLink,...1906.aspx.
111658544071.zip
prograficaUser is Offline
2010-10-07 06:17 AM
Hi All, I followed all methods I could find. But i still cannot access the login page. I checked database for that coloum. It is 'Null' at the moment.
2010-10-07 12:00 PM
What happens when you try to visit the login page?
2010-10-07 10:18 PM
Its not redirecting to login page even if we type it as http://localhost:8086/Login.aspx
2010-10-07 10:21 PM
Nothing happen. Just stay at home page.
2010-10-08 12:54 PM
Is this a new installation, or one that has quit working?  Which version of DotNetNuke?
k.anderson3454User is Offline
2010-12-14 10:41 PM
Is there any way to resolve this?
[url=http://naturalhealthcarereviews.com/mens-health/semenex/]semenax[/url]
2010-12-14 11:26 PM
If navigating to login.aspx directly doesn't work, see if this old standby helps.  If not, ask again and I may have some other suggestions.
Samar ShahUser is Offline
2011-02-10 05:33 PM
Thanks Lee! The trick to open Login page worked for me when I have freshly installed DNN 5.6.1 and found Login page not working. Using this technique I could login once and create a new Page called Login, place Login module on it and tag that Login page in Site settings. Thanks again. But I have similar problem with Home.aspx page as well. After logout or pressing on Home goes to Home.aspx and the page does not exists. It should have pointed to default.aspx. Not sure why Please provide magic trick again! If you can explain why it behaves like this pls pls pls do so.
2011-02-10 06:09 PM
What is configured as your Home page on the Site Settings page?
rubiciteUser is Offline
2011-06-04 05:13 AM
I had this problem occur seemingly at random, but it was after a database restore due to some sort of database corruption.
I used the web-developer toolbar in firefox to delete my domain cookies -- after this happened, the login control was visible again.
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
