module visibility
Last Post 2007-12-22 05:00 PM by Joseph Craig. 1 Replies.
soodUser is Offline
2007-12-22 06:19 AM
  I am working on the site but when i am making text module then the heading appears that visible to administrator.....
an when loging from user details then it is giving msg"yo have no permission to view this module with in the portal".
plz help
2007-12-22 05:00 PM
Start by checking the user's permissions and security roles. Also check the permissions for the page and for the modules within the page.
DNN nav issue by imran shaikh
