Change Fields of Registration Page
Last Post 2008-11-01 12:38 AM by Joseph Craig. 5 Replies.
zealousweb1User is Offline
2007-12-20 06:56 AM
I Want to Change and Add More Fields in Registration Page.
Please help me.
Ex.
FirstName
LastName
Telephone No
Fax
Email
Website
So, how can i chagne it.
Thank You in advance.
saintXUser is Offline
2007-12-20 07:41 AM
Hello, you will find an excellent and step by step guid for it in tutorials issue nr. 13:
http://www.dnncreative.com/Home/Iss...fault.aspx
http://www.dnncreative.com/Tutorial...fault.aspx">How to Manage Profile Properties in User accounts for DotNetNuke 4.3 / 3.3(Creating a custom registration page)
(6 videos - 53 min)
I used it for DNN 4.5.5.
2007-12-20 11:42 AM
Hello saintX
Thanks for your help.
But, ihave already do that. but, it is showing fields in registration page.
Is there any other way like coding or any other ?
Then please tell me with steps.
Thank You.
Bye.
2007-12-20 12:21 PM
If you go to Adminstrator/User acconts and then click on manage profile properties and then check your desired fields: Telephone Nr. , Fax, and Website (just click on the check box beside them) they will appear on the registration page. But please notice:
You can't remove the default fields of the registration page like display name or User name.
What I did was changing the name of them in admin/languages/language editor. Once you are there expand the tree menu:
localressources/admin/Users/App_localressources/profile.ascx and change the value of dispalyed fields. For example I changed the value of lastname to company name.
Hope it helps.
joeUser is Offline
2008-10-30 09:26 PM
What if i added a new profile property and i want the user to able to edit this value later on?
all i see in the edit profile are the regular registration fields
thanks
Joseph CraigUser is Online
2008-11-01 12:38 AM
Did you click the "Manage Profile" link? You'll see all of the profile properties there.
informative!!!
informative!!!
