How to modify the search box??
Last Post 2007-12-10 09:37 AM by Lee Sykes. 1 Replies.
tlyczkoUser is Offline
2007-12-07 01:58 PM
For example, if I want to color and size the input box??
If I want to use an image (e.g. magnifying glass) instead of the button??
If I want to modify the button??
Thank you, Tom
2007-12-10 09:37 AM
Here is an example:
< Object >
    < Token >[SEARCH]< /Token >
    < Settings >
      < Setting >
        < Name >CssClass< /Name >
        < Value >SkinItem< /Value >
      < /Setting >
      < Setting >
        < Name >ShowSite< /Name >
        < Value >False< /Value >
      < /Setting >
      < Setting >
        < Name >ShowWeb< /Name >
      < /Setting >
      < Setting >
        < Name >Submit< /Name >
        < Value >< ![CDATA[< img src="images/Search_Button.gif" alt="Search" / >]] >< /Value >
      < /Setting >
    < /Settings >
  < /Object >
(spaces added before < and > so that it displays in the forum)
/* shrink width of DNN search box */
#dnn_dnnSEARCH_txtSearch
    width: 100px; /* shrink */
    margin: 10px 0 0 18px; /* center */
    font-size:10px;
/* position search image */
#dnn_dnnSEARCH_cmdSearch img {
    border: 0;
    position: relative;
    top: 2px;
    left: -3px;
DNN nav issue by imran shaikh
