Why am I not able any more to login after having suscribed
Last Post 2006-05-15 09:55 PM by Kim Seba. 2 Replies.
kim SebaaUser is Offline
2006-05-15 09:20 PM
    I could login untill I have suscribed to have access to the tutorials. I could download one video or two videos. Since then, I cannot. I have registered with a new name user Wansen2 in order to post this message.
    My disabled login was Wansen.
    Thanks for your help.
    2006-05-15 09:29 PM
    I've un-locked your account. DotNetNuke automatically locked your account due to a series of un-successful login attempts. I also requested the site to email your password to your email address so that you can login successfully.
    If you need anything else, let me know, thanks,
    Kim SebaUser is Offline
    2006-05-15 09:55 PM
    Thank you for your help. I didn't notice that it's case sensitive. That was my fault then.
    You do a good job. The videos help me so much. Even if my english is not perfect, i can follow since it's spoken slowly and clearly.
    Thanks again
    I'm confused by this, too.
    We are running DNN 6.x
    You should be able to use CE even if you have a high traffic site. To develop your site without p
    RE: Rename or move site from domain name to subdomain name by Joseph Craig
    It is easy. 1. Go to Admin, Site settings and add a Portal Alias for new.websitename.com 2.
