Dynamic HouseMenu?
Last Post 2007-08-23 09:54 PM by Lee Sykes. 1 Replies.
hadar kUser is Offline
2007-08-23 12:31 PM
Hi Lee,
Still looking 4 a good rtl menu, I was testing housemenu.
Seems really weird that in order to get a sub menu I need to define a different skin to every page in my site. Or did I get it wrong? I'm refering to the "Scope" definiton.  Plus, I coudln't find a way to make the sub menu open like in solpart (while hovering a parent in the root menu). My sub menu is vertical.
Is there a fast way to make the sub menu opened neatly under the root menu, without creating a new menu just for the subs, moreover, for every page?(!)
2007-08-23 09:54 PM
If your sub menu is separate to the main menu and not part of the menu, such as in the red leaf skin. Then yes you end up setting this up by creating different skins for each main menu item. - You don't need to create a skin for every single page, just each main menu item.
This isn't a great method as it involves a lot of work, and I've heard that the snapsis css nav menu handles elements like this much better.
I haven't experimented with a solpart look CSS menu as the HouseMenu styles that I originally tried did not work correctly in IE7 and I haven't had the need to do it since. - Again though, I think the snapsis menu has this covered - have you experimented with it yet? - There is a special 35% discount offer available to subscribers
DNN nav issue by imran shaikh
I successfully installed DNN 6 on my local machine using IIS 7.5. Its working good. When I attach to
RE: Module Security permissions by Bhushan Gholap
Thanks for the reply!!! I would definitely contact sales engineer team of DNN.
RE: There's a tutorial for this somewhere by Eric W
The error I got was the Connection Error(s): Index #: 0 Source: .Net SqlClient Data Provider
RE: DNN 6 Modules Not Showing by Joseph Craig
Where can I see this? If you'd like to send me some login credentials so that I can look, use the c
RE: DNN 6 Modules Not Showing by Mike DeBaise
No, modules are set to all viewers/users. Just cant figure this out, it really doesnt make any sense
