Validation Errors From text/html module?
Last Post 2007-04-16 03:09 PM by Lee Sykes. 1 Replies.
George HummerUser is Offline
2007-04-15 06:40 PM
I am receiving these validation errors:
an id="dnn_ctr568_ContentPane" align="left"><!-- Start_Module_568 -->
Could anyone tell me if this is coming from a container, or the text/html module. I recently reworked the red leaf skin, installed the house menu and FCK editor.  The text/html module is the only module I am using on my main portal page right now at http://www.rightontop.net . I got rid of 36 validation errors already.  Just 2 left.  I just don't know the source of these errors.
Thanks you in advance,
George Hummer
Florida USA
2007-04-16 03:09 PM
Have you read this post: Text/HTML module causing invalid XHTML
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
