Complex module
Last Post 2007-03-13 01:45 PM by Andy Hock. 1 Replies.
ARASHUser is Offline
2007-03-11 05:02 AM
PLEAE HELP ME , I HAVE SEARCHED MANYWEBLOG AND MANY ONLINE RESOURCE TO SOLVE THS PROBLEM BUT I COUDNT FIND ANY ANSWER ,
I AM DEVELOPING MODULE WICTH HAS MANY PAGES LIKE ACTIVE FROUM MODULE , HOW CAN I NAVIGATE TO DIFRENT VIEW , AND WHAT IS THE KEY I SHOUD DEFINE FOR EACH PAGE ?
LET SAY IT MORE CLEAR , FOR EXAMPLE I HAVE AN ADDMIN CONTROL PANEL IN MY MODULE WIVH THE ADMIN CAN GO THROUGH DIFFENT OPTION AND PAGES IN MODULE ,
HOW CAN I IMPLEMENT THAT ?
BEST REGARDS
Andy HockUser is Offline
2007-03-13 01:45 PM
You should check out the DotNetNuke Wizard control. That might do what you want.
However, if you want to create a multi-page 'module' what you are really doing is creating multiple modules...unless all this is being done in the 'Edit' page (and if it's in 'Edit', then you should check out the docs for the DNN Wizard control).
Hope this helps.
DotNetNuke and .NET web parts, web services, modules and code snippets.
