Could not load Type
Last Post 2007-03-01 07:09 AM by MITESH SHAH. 0 Replies.
MITESH SHAHUser is Offline
2007-03-01 07:09 AM
I am facing following error while adding new .ascx module to dnn 4.4.1. The .ascx file contains td and tr only. Not a single server control contain at .ascx file.
DotNetNuke.Services.Exceptions.ModuleLoadException: Could not load type 'Chenoa.DNN.Modules.trustCorporation.trustCorporation'. ---> System.Web.HttpParseException: Could not load type 'Chenoa.DNN.Modules.trustCorporation.trustCorporation'. ---> System.Exception: Could not load type 'Chenoa.DNN.Modules.trustCorporation.trustCorporation'. ---> System.Exception: Could not load type 'Chenoa.DNN.Modules.trustCorporation.trustCorporation'. ---> System.Web.HttpException: Could not load type 'Chenoa.DNN.Modules.trustCorporation.trustCorporation'. at System.Web.UI.TemplateParser.GetType(String typeName, Boolean ignoreCase, Boolean throwOnError) at System.Web.UI.TemplateParser.ProcessInheritsAttribute(String baseTypeName, String codeFileBaseTypeName, String src, Assembly assembly) at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData) at System.Web.UI.TemplateParser.ProcessMainDirective(IDictionary mainDirective) at System.Web.UI.TemplateControlParser.ProcessMainDirective(IDictionary mainDirective) at System.Web.UI.TemplateParser.ProcessDirective(String directiveName, IDictionary directive) at System.Web.UI.BaseTemplateParser.ProcessDirective(String directiveName, IDictionary directive) at System.Web.UI.TemplateControlParser.ProcessDirective(String directiveName, IDictionary directive) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.UI.Skins.Skin.InjectModule(Control objPane, ModuleInfo objModule, PortalSettings PortalSettings) in C:\Projects\Avenel\Library\Components\Skins\Skin.vb:line 449 --- End of inner exception stack trace ---
Can anyboady help me out.
