what is the recommended cache setting for RSS module
Last Post 2007-04-10 09:08 AM by Lee Sykes. 1 Replies.
eddyUser is Offline
2007-02-27 02:31 PM
Can someone tell me what is the recommended cache setting for the news feed module?  Should I set it to 0 seconds or 1 minute or 1 hour or 3 hours or...?
I noticed that some modules automatically set the cache to a certain value when I initially add it to a page (ie. the annoncement module).  However, for the news feed module, the cache is initially set to zero.  Is it because no cache is the best choice?
I have experimented in the past couple of days by setting the cache to 0 and to 3600- each has its own disadvantage.
With 0 cache, 10% (rough estimate) of the time, I get the "can not connect error" and the user need to refresh the browser.  With 3600, I almost always get the news feed loaded correctly.  However, the big problem is that 1% (rough estimate) of the time, the news feed is completely blank and it remains blank no matter how many times I refresh (I assume it remains like that for 3600 seconds.)
2007-04-10 09:08 AM
Did you find an ideal setting for this?  I tend to use the Orizonti news feed module and within this you can set a cache time for each individual RSS feed and display multiple RSS feeds within the one module.  So I tend to set the cache dependant on how often the RSS feed is updated.  For instance if it is a regularly updated feed I may set the module to check the RSS feed every 30 minutes, however for RSS feeds that are not updated as often, I may check it every eight hours or longer. Hope this helps,
