Re: SQL SERVER 2008 R2 Remote connection
Last Post 2012-02-08 02:44 PM by Joseph Craig. 1 Replies.
Prakasam SrinivasanUser is Offline
2012-02-07 12:09 PM
I have successfully configured MSSQL Server 2008 r2 remote connection. I am using windows 7 and it has two user like Admin and Others.
If I Login into windows 7 Others User it will connect successfully. If I Login into windows 7 Admin user it shows the following error.
TITLE: Connect to Server
Cannot connect to I5PC\SQL2008EXPRESS.
ADDITIONAL INFORMATION:
Login failed. The login is from an untrusted domain and cannot be used with Windows authentication. (Microsoft SQL Server, Error: 18452)
For help, click: http://go.microsoft.com/fwlink?Prod...nkId=20476
BUTTONS:
OK
Joseph CraigUser is Online
2012-02-08 02:44 PM
Set up a user with dbo privileges and set the connection string for that user, rather than using Windows authentication.
RE: Deploying dnn by Sameer
Just sent it.
