Dnn local setup problem
Last Post 2012-02-06 11:19 AM by Sameer. 1 Replies.
SameerUser is Offline
2012-02-06 10:02 AM
Hi All
i have just installed the new site files on my local computer set the connection string and while running getting this error
its dnn 4.4
DotNetNuke Upgrade Error
The Assembly Version ( [ASSEMBLYVERSION] ) does not match the Database Version ( [DATABASEVERSION] )
ERROR: Could not connect to database.
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: TCP Provider, error: 0 - No connection could be made because the target machine actively refused it.)
2012-02-06 11:19 AM
this is error is resolve now now getting this one
Server Error in '/cooperpharma.ma' Application.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Line 133:
Line 134: ' all of the logic which was previously in Application_Start was moved to Init() in order to support IIS7 integrated pipeline mode ( which no longer provides access to HTTP context within Application_Start )
Line 135: Initialize.Init(app)
Line 136:
Line 137: 'run schedule if in Request mode
Source File: c:\inetpub\wwwroot\cooperpharma.ma\App_Code\Global.asax.vb Line: 135
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
DotNetNuke.Entities.Portals.PortalInfo.Fill(IDataReader dr) +1385
DotNetNuke.Common.Utilities.CBO.FillObjectFromReader(Object objObject, IDataReader dr) +82
DotNetNuke.Common.Utilities.CBO.CreateObjectFromReader(Type objType, IDataReader dr, Boolean closeReader) +121
DotNetNuke.Common.Utilities.CBO.FillListFromReader(Type objType, IDataReader dr, IList objList, Boolean closeReader) +67
DotNetNuke.Common.Utilities.CBO.FillCollection(IDataReader dr, Type objType) +41
DotNetNuke.Entities.Portals.PortalController.GetPortals() +56
DotNetNuke.Common.Initialize.CacheMappedDirectory() +38
DotNetNuke.Common.Initialize.InitializeApp(HttpApplication app) +714
DotNetNuke.Common.Initialize.Init(HttpApplication app) +145
DotNetNuke.Common.Global.Global_BeginRequest(Object sender, EventArgs e) in c:\inetpub\wwwroot\cooperpharma.ma\App_Code\Global.asax.vb:135
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:2.0.50727.3625; ASP.NET Version:2.0.50727.3618
any help
RE: Deploying dnn by Sameer
Just sent it.
