Module permission does not work!
Last Post 2012-02-06 04:03 PM by Joseph Craig. 3 Replies.
Author Messages Not Resolved
Abraham TameruUser is Offline
2012-01-31 04:50 AM
I use CE dnn 6.0.1.
I have some modules in my site (page) that I don't want a user to change. Using the host account I changed the permission of these modules: I unchecked the "Inherit View permissions from page" and I edit manually the permissions. All "Edit Module" are not checked.
When I log in using the user account, I still can access the modules and even change their settings.
I also tried to deny all "Edit Module" options but the result is the same.
How can I protect a module from being accessed or changed by that user?
Thanks.
2012-02-01 11:48 PM
When you login are you a member of the Administrators security role? I don't believe that you can deny administrators to right to administer a module. Users who aren't Administrators will not be able to modify it.
2012-02-06 10:32 AM
I created a special role for the user to administer the site. The user is not a member of the Administrator role. When I login as the user, I don't have the "Admin" and "Host" (I see "Tools" but empty) menus.
2012-02-06 04:03 PM
RE: Deploying dnn by Sameer
Just sent it.
