I seem to have stumbled onto some Firefox-specific problem that is making me tear my hair out. As you can see in the screenshot, my site looks fine in Chrome (on the left) but in Firefox the header items are overlapping. It also looks fine in Safari and in IE8. Some of the pages use different skins, but the code for the header content is the same for all of them, so the same problem appears on every page. Once we get to the top of the next element on the page, everything lines up from there on down.
My skin.css file validates at level 2.1.
My FireFox Web Developer toolbar shows 5 errors; four of them are related to the menus, but shouldn’t be messing up the positioning. I think the last one is probably a DNN thing…
Expected declaration but found ‘url’. Skipped to next declaration.
http://ktw.baessolutions.com/Portal...20Skin/CSS BarOnly/Css BarOnly.css Line: 15
Error in parsing value for ‘width’. Declaration dropped.
http://ktw.baessolutions.com/Portal...Suckerfish" target="_blank" rel="nofollow">http://ktw.baessolutions.com/Portal...Suckerfish" target="_blank" rel="nofollow">http://ktw.baessolutions.com/Portal...Suckerfish Arrow hor grey/SuckerFish Arrow hor grey.css Line: 4
Unknown property ‘font-color’. Declaration dropped.
http://ktw.baessolutions.com/Portal...Suckerfish" target="_blank" rel="nofollow">http://ktw.baessolutions.com/Portal...Suckerfish" target="_blank" rel="nofollow">http://ktw.baessolutions.com/Portal...Suckerfish Arrow hor grey/SuckerFish Arrow hor grey.css Line: 20
http://ktw.baessolutions.com/Portal...Suckerfish" target="_blank" rel="nofollow">http://ktw.baessolutions.com/Portal...Suckerfish" target="_blank" rel="nofollow">http://ktw.baessolutions.com/Portal...Suckerfish Arrow hor grey/SuckerFish Arrow hor grey.css Line: 83
Unknown property ‘behavior’. Declaration dropped.
http://ktw.baessolutions.com/default.aspx
Line:514 (line 514 reads: img { behavior: url(iepngfix.htc) })
If I view source for the page, save the file and run it through the w3C validator in XHTML transitional, I get two errors:
Line 513, Column 23: document type does not allow element "style" here
The line falls within a block of code relating to one of the modules on my page (The pageflip in the upper right corner)
Line 577, Column 7: end tag for "div" omitted, but OMITTAG NO was specified
Not sure what it is, but I don’t think it has anything to do with my menu problem, seems to be a jscript call of some sort
In my skin package is a portal.doctype.xml file, which declares XHTML 1.0 Transitional
Attached are:
screenshot.jpg, showing the problem
Portal.ascx
(named portal.txt as my attachment)
skin.css (named skin.txt as my attachment; note there's lots of extra commented-out code in this one because I haven't cleaned it up yet)
I would be delighted with any help I can get on this one, I’ve run out of ideas…
Liz
