How to add Duplicate Token
Last Post 2010-09-07 01:25 PM by Lee Sykes. 4 Replies.
programmerboyUser is Offline
2010-09-03 05:40 PM
How do you add a same token twice? I tried the following <%@ Register TagPrefix="dnn" TagName="USER" Src="~/Admin/Skins/user.ascx" %> <%@ Register TagPrefix="dnn2" TagName="USER2" Src="~/Admin/Skins/user.ascx" %> <dnn2:USER2 CssClass="loginLinks" runat="server" ID="dnnUser2" URL="" Text="Subcribe for email alerts" /> But that is not working. When I am clicking on the dnnUser2 link, it is opening a new window that is completely blank and javascript in the URL. I have the full code like this (if it helps) <% If DotNetNuke.Security.PortalSecurity.IsInRole("Registered Users") = False Then%> <dnn2:USER2 CssClass="loginLinks" runat="server" ID="dnnUser2" URL="" Text="Subcribe for email alerts" /> <% End If%>
2010-09-04 01:06 AM
You only need to register the control once. Then you can specify it many times. If you are familiar with ASP.NET controls it's just like having many text boxes on a page.
So, remove the second register. I'm surprised that this did not generate an error.
2010-09-04 01:35 AM
Posted By Joseph Craig on 03 Sep 2010 7:06 PM
It was not working thats why I registered it 2nd time but no luck as well. Ok, to make things simple, how can I use same token multiple times? I remember there was a tutorial where Lee used the same token (most probably for menu) couple of times.
2010-09-04 02:05 AM
You can do something like this:
< dnn:SOLPARTMENU runat="server" id="dnnSOLPARTMENU1" / >
< dnn:SOLPARTMENU runat="server" id="dnnSOLPARTMENU2" / >
You'll note that I put in some spaced to that this will post.  Also, I left out a lot of the "normal" attributes.
2010-09-07 01:25 PM
A tip to remember:
In any HTML you can only have one id on a page, but you can have many instances of the same class on a page.
informative!!!
informative!!!
