send one dynamic form data to another dynamick form
Last Post 2010-06-18 02:38 AM by Joseph Craig. 1 Replies.
kishorUser is Offline
2010-06-17 07:38 AM
I am using two dynamic form in my site,
Test 1 page :- here one form with only one field that is comment
Test 2 page :- comment box with other fields,
when user fills the comment in the first form and when it click on the  submiit buttons it should redirect to the test 2 page with Test 1 page data and then when user click on the Test 2 page that should fire the events.
It is redirecting to the Test 2 page but not able to send the data form Test 1 page...
Is there any setting for this.
2010-06-18 02:38 AM
Here is one way that you can do it:
On the first page, you will "post" the form contents to the second page so that all of the information is contained in query string variables.
The second page will pick these up and fill them in on the second page. There are options for fields on the second page to get values from query string variables. There are other options. If you don't want to show the information from page 1 on page 2, use hidden fields.
