Module not in use
Last Post 2010-06-10 01:32 PM by Ivan Marko. 2 Replies.
Ivan MarkoUser is Offline
2010-06-10 12:54 PM
Hi everybody, I have a little problem with multilanguage pages. I use MLHTML and ModuleLocalization modules but there i not everything all right. When I looked into settings of theese modules I found "Not in use". What can I do to make it "In use"? There is a picture :
2010-06-10 01:24 PM
I assume that ModuleLocalization is marked as not in use because it's actually not placed on a page. As the description says, it is just a "dummy" module that is needed to install shared code in the application. I don't think that's there is any problem.
Note that MLHTML is marked as being used.
2010-06-10 01:32 PM
Oh! How a simply solution. Thanks. I have to looking where is the fault again.
