Web.UI Error
Last Post 2010-06-09 01:52 PM by Joseph Craig. 1 Replies.
HariUser is Offline
2010-06-09 04:04 AM
Hi I am using DotNetNuke 5.4.1.By Mistake I had installed OnyakTech Library6.8, Actually we have install OnyaktechLibrary6.8(5.2.1 or Newer). My website stopped running throwing an error counldnot find the WebTelerik.UI version Specified. Onyak Team replied me to copy the Web.Telerik.UI.dll from dnn installation ZIP file to Bin folder. I did as they specified and got the error as "Compiler Error Message: BC32206: The project currently contains references to more than one version of Telerik.Web.UI, a direct reference to version 2009.3.1104.35 and an indirect reference (through 'DotNetNuke.Web.UI.WebControls.DnnWindowManager') to version 2010.1.309.35. Change the direct reference to use version 2010.1.309.35 (or higher) of Telerik.Web.UI." Please help me out of this issue.
2010-06-09 01:52 PM
It would seem that you now have two copies. You will need to get rid of the other one.   It's possible that you have a copy of the DLL somewhere other than in the bin directory, so you may have to look for it.
In my test installation (DotNetNuke 5.4.23) the file is Telerik.Web.UI.dll.
