Login - User Authentication
Last Post 2010-06-02 02:07 AM by Joseph Craig. 1 Replies.
VikUser is Offline
2010-06-02 01:30 AM
I am a developer and I am new to DNN. I need to create a new module for our dnn web site - for User Authentication which will use web services from another company and use their database to save new user or login existing users there. What should I do? Can I download free any module for it? Please tell me how to use DNN and step by step how to create the new custom login module? Thank you.
2010-06-02 02:07 AM
There are several paths that you can go down to do this.
Perhaps the simplest is to create a custom "authentication provider." If you are interested in doing that, take a look at Joe Brinkman's blog at DotNetNuke.com.
Brandon Haynes has a multi-factor authentication provider that is described at http://dnnmultifactor.codeplex.com/.
If you need to go further and provide a membership provider or other providers, I'll need to know more details about what you are doing.
