New Tag & Subject feature in DNN 5.4.2
Last Post 2010-06-17 05:21 PM by Lee Sykes. 2 Replies.
The Mobile GuruUser is Offline
2010-06-01 01:47 PM
I have just installed 5.4.2 onto one of my portal/websites and find this new tag/subject feature. Can anyone give me a simple explanation of what this is, how it works and how to remove it from the screen?
2010-06-02 02:10 AM
There are several new features that, I think, we are all waiting to see explained.
2010-06-17 05:21 PM
hello,
We cover these new features in detail in the next issue of DNN creative. If you want to remove the tag feature at the bottom of the screen, this is a skin object in the Minimal Extropy skin. All you need to do is edit the code in your skin and remove the line of code for the skin object.
