Dropdown Nav covered in Mozilla
Last Post 2010-06-01 08:10 PM by Em_Jane. 2 Replies.
Em_JaneUser is Offline
2010-05-20 11:02 PM
Hello All,
I wrote a rotating java script banner and placed it in an HTML module directly under the navigation bar at the top.  Now my drop-down navigation is covered by the images, only in Mozilla. In IE 7,8 and Safari, it's all working as intended, which is the opposite I'd expect.   I tried adjusting the z-index on the .MainMenu_MenuItem, but it didn't work.
Any suggestions?  Thanks in advance...
-Em
2010-05-24 01:25 PM
z-index: 1000;
should be how to do it, make sure you apply it to the sub menu items
2010-06-01 08:10 PM
Thanks.  This ended up being what fixed it:
 .MainMenu_SubMenu, .MainMenu_SubMenuItem, .MainMenu_MenuItem {z-index:1000 !important; }
