For Active Forums....
Last Post 2010-05-21 12:39 PM by Joseph Craig. 1 Replies.
mgordonUser is Offline
2010-05-19 03:42 PM
I need employees to be able to post anonymously for certain message boards.  When it has the quick reply box below the topic, I don't want the Username field to be showing, nor required, and also don't want the CAPTCHA code there.  Can you advise me if it's possible to have these removed?
Mark Gordon
Webmonkey
2010-05-21 12:39 PM
You will need to modify the templates for ActiveForums to suppress display of the user.
You can configure forums to accept posts from "All Users" but posts from logged in users may still have their userids stored in the data tables. That would give anonymity on display, but YOU could figure out who they are.
I think that CAPTCHA is a configuration setting.
