Installing Feedback Module
Last Post 2010-05-18 02:18 PM by Joseph Craig. 1 Replies.
truewarpitUser is Offline
2010-05-18 12:23 PM
Hi There,
I hope someone there can answer me this... I'm installing the new release Feedback module beta 5. I encountered this error while trying to install it... Please check below:
SQL Execution resulted in following Exceptions: System.Data.SqlClient.SqlException: 'PK_DNN_Feedback' is not a constraint. Could not drop constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDataProvider.ExecuteADOScript(String SQL) at DotNetNuke.Data.SqlDataProvider.ExecuteScript(String Script, Boolean UseTransactions) ALTER TABLE dbo.Feedback DROP CONSTRAINT PK_DNN_Feedback System.Data.SqlClient.SqlException: Table 'Feedback' already has a primary key defined on it. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDataProvider.ExecuteADOScript(String SQL) at DotNetNuke.Data.SqlDataProvider.ExecuteScript(String Script, Boolean UseTransactions) ALTER TABLE dbo.Feedback ADD CONSTRAINT PK_DNN_Feedback PRIMARY KEY CLUSTERED ( FeedbackID ) WITH( STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY] System.Data.SqlClient.SqlException: There is already an object named 'FK_Feedback_Modules' in the database. Could not create constraint. See previous errors. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDataProvider.ExecuteADOScript(String SQL) at DotNetNuke.Data.SqlDataProvider.ExecuteScript(String Script, Boolean UseTransactions) ALTER TABLE dbo.Feedback WITH NOCHECK ADD CONSTRAINT FK_Feedback_Modules FOREIGN KEY ( ModuleID ) REFERENCES dbo.Modules ( ModuleID ) ON UPDATE NO ACTION ON DELETE CASCADE NOT FOR REPLICATION System.Data.SqlClient.SqlException: Cannot find the object "dbo.DNN_Feedback" because it does not exist or you do not have permissions. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDataProvider.ExecuteADOScript(String SQL) at DotNetNuke.Data.SqlDataProvider.ExecuteScript(String Script, Boolean UseTransactions) ALTER TABLE dbo.DNN_Feedback SET (LOCK_ESCALATION = TABLE) System.Data.SqlClient.SqlException: Error: The new name 'SenderName' is already in use as a COLUMN name and would cause a duplicate that is not permitted. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDataProvider.ExecuteADOScript(String SQL) at DotNetNuke.Data.SqlDataProvider.ExecuteScript(String Script, Boolean UseTransactions) /* Modify the Feedback Table to rename the field CreatedByName and CreatedByEmail to SenderName and SenderEmail */ if col_length('dbo.[Feedback]','CreatedByName') is not NULL BEGIN EXEC sp_rename 'dbo.[Feedback].CreatedByName', 'SenderName', 'COLUMN' END
Need some answers here. Thank you...
Cheers,
Truewarpit
2010-05-18 02:18 PM
You are installing a Beta version of the Feedback module.  Beta software is not recommended for production.
I assume that you are installing over an existing copy of the Feedback module.  The errors seems to be related to that.  So, if you really do want to install the Beta version, I would recommend that you completely uninstall the existing module so that this will install as a new install.
But, I'd recommend that you revert to what you have and report the errors to the Feedback module team so that it can be fixed.
