UDT - CSS Styling
Last Post 2010-05-14 02:23 PM by cube consulting. 3 Replies.
CelesteTUser is Offline
2010-05-12 06:54 AM
Hi, I am currently styling a UDT table using the CSS classes. I can change the font etc using the CSS classes however, do you know how I would get spaces between the various column headings (when using the default grid table and "Normal UDT_Table*"). I would prefer more space between them as they currently only space as wide as the largest record. Thanks.
cube consultingUser is Offline
2010-05-12 08:35 PM
Hi, I am fighting my way through the Forms and Lists module but can't seem to find any CSS templates for the form lay-out.. Does anybody have any examples I could use? I want to use the module to create a very simple contact form where first and last name can sit on the same line, and then some address information beneath it..
Many thanks for any positve thoughts you may have!
Aad
2010-05-14 07:50 AM
Have you tried identifying any class of ids that you can add the CSS spacing to?
This tutorial outlines how you would identify any potential classes or ids:
2010-05-14 02:23 PM
Hi Lee, I installed Firebug and I have discovered css styles, I plan on adding some styling to my skin.css to see if this changes behaviour..
