Regarding Editor
Last Post 2010-03-22 08:42 PM by Joseph Craig. 1 Replies.
prithvirajUser is Offline
2010-03-19 04:47 PM
Pls let me know whar folders we need to upload when we are changing editors. Suppose i have cute editor in my site but if i want FCk editor or RAD editor. So after changing in the requried thing in web.config what others folder i need to upload.  Folders like Providers, documentaion etc.
  So i need to know exactly what folders i need to upload for this.
 Pls help me on this.
2010-03-22 08:42 PM
If you want to switch to one of the other editors, I'd recommend that you get in touch with the other editor's developer.
That said, the Telerik Rad Editor is shipped with recent versions of DotNetNuke. Telerik provides a free module that you can install. It permits you to switch back and forth between the FCK editor and the Telerik Editor.
DNN nav issue by imran shaikh
