How to use dotnetnuke module
Last Post 2007-03-23 12:18 PM by Andy Hock. 4 Replies.
jags jagsUser is Offline
2006-12-27 08:07 AM
hi all,
i just wanted to know how to use dotnetnuke module in separate application(ie the new dot.net application)..
could u please help me  in that.. , i am new to this dotnetnuke...
Thank in advance
  jagadish
markpUser is Offline
2007-01-02 05:55 PM
jagadish.
Which module are you asking about?
2007-01-29 07:24 AM
 thanks for ur reply..
i want to create a portal application using dotnetnuke..
i need to create portal application by
1) using the existing DNN ?
OR
2) i need to create a new application and use all dll of DNN in that application ?
so could u please tell me , how DNN helps me
waiting for ur reply ..
2007-03-21 08:05 PM
I dont think I  am really qualified to explain this but here goes.
Dnn is an application that allows you to create multiple portals within one "shell".  This allows you to share css files and modules between parent and child portals.   There is additiona sharing, very limited sharing , capabilites of sharing between child portals to its parent ( I have yet to verify how well it does this).
Andy HockUser is Offline
2007-03-23 12:18 PM
You need to download the starter kit, and some templates will be created. You can use either Visual Web Developer or Visual Studio 2005. There are a ton of documents that come with DotNetNuk that will at least get you started to understand how to build your own modules.
DotNetNuke and .NET web parts, web services, modules and code snippets.
